2020-02-26 11:30 AM
I was planning to design a hand held uhf rfid reader using this ic. Is it possible to design one using this ic? if yes how to design the antenna for this reader.? What are the challenges in designing an rfid reader. Please help.
2020-03-05 4:38 AM
yes, it is possible to design a handheld RFID reader with the ST25RU3993.
This IC is even ideal for such kind of applications, because of the low power consumption.
The antenna design of handheld readers should at least cover the following:
Main challenges of UHF RFID reader design:
The ST25RU3993 EVAL board is a very good starting point for your design.
If you use this as a reference, you will be successful.
Best regards,
Marcel
2020-03-05 4:38 AM
Best regards,
Marcel
