2023-07-17 1:51 PM
Where does the external pad get connected on the ST25R3918-AQWT package? Ground?
2023-07-18 6:41 AM
Hi Ted,
Thermal Pad must be grounded for ST25R3916/16B/17/17B/18/19/19B/20/20B.
Rgds
BT
2023-07-18 1:22 AM
which pin number/pin name do you refer to?
Rgds
BT
2023-07-18 6:12 AM
Hi Brian,
Thanks for the quick response. The pin number is 33, which is named Thermal Pad. It is a 3.5mm x 3.5mm square pad on the bottom surface of the chip.
Ted
2023-07-18 6:41 AM
Hi Ted,
Rgds
BT
2023-07-18 7:04 AM
Thanks so much, Brian.
