2014-06-17 02:27 AM
Hi
I'm using the M24LR04 in Harvesting Mode to supply an STM32L151. When the uC powers up, it reads data from an sensor and write them to the M24LR. This is than read from an NFC Handheld.My problem is, when the Handheld approaches, first the M24LR starts to communicate with the handheld, before the uC powers up and refreshes the Data.
So i want to disable the RF communication until the STM is on. I know there is the M24SR devices which had the RF disable Pin, but unfortunately my App is ISO15693 (and notISO 14443)....
Is there another possibility... Thanx regards otmar #vout #rf-wip-busy #m24lr #m24lrSolved! Go to Solution.
2014-07-07 01:05 AM
What you can try to do is:
Let the Vout pin unconnected
Connect RF WIP/busy to a forward bias direction diode D1
And AC1 to a forward bias direction diode D2
D1,D2 connected to the same point, then to a resistance to a point A
Point A
link a capacitance to the ground
Connected to your micro
And the VCC is connected to an I/O of the Micro in order to be driven
And VCC+ DSA+SCL, all connected to your sensor.
Awaiting your feedback,
Best Regards,
ST NFC/RFID Dynamic tag support
2014-07-07 01:05 AM
Point A
Best Regards,
2014-07-10 06:08 AM
Hello
Thanks for your reply Please can you check the attachment, so i don't misunderstood your circuit best regards otmar ________________ Attachments : M24LRx_disable.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtzA&d=%2Fa%2F0X0000000aaw%2FfJRKtYgUsYr.PFv84RtCr4LtstTq_txHRRNGXpWFId8&asPdf=false2014-08-29 01:40 AM
2021-01-19 09:02 AM
I'm facing the same problem discussed by @otmar but I didn't really understand Galligani's answer. Microcontroller is powered by energy harvesting Vout pin, so I can't leave it unnnected. Any ideas?
