2021-04-13 11:44 AM
Hello Folks,
We intermittently see an "invalid protocol - 0x83' error while reading data.
send_cmd 0x04 0x04 0x16 0x00 0x00 0x00
rcv_hdr 0x83 0x00
This happens intermittently and I have not been successful in reproducing the error.
Usually a restart or connect helps to resolve the error.
Any pointers on what is causing the error and how to reproduce it on a testing environment?
Best Regards,
Abhi.
2021-04-13 12:03 PM
Hi Abhi,
can you provide more information about the firmware being used:
I suspect that sometimes the SendRcvd command is used while the protocol has been reset to field off.
Can you connect a logic analyser on SPI (CLK, SS, MISO, MOSI) +IRQ_OUT and provide a trace?
Rgds
BT
2021-04-13 12:03 PM
Hi Abhi,
Rgds
BT
