2023-06-02 08:24 AM
2023-06-05 04:45 AM
Welcome, @Terry Rose, to the community!
The differences between STM704 and STM806 are indeed not listed on the first page of the data sheet, but can be found after a close look at the parameter tables:
So to answer your question, the cheaper STM806 is the one to use if you have lower accuracy requirements.
Hope that helps?
/Peter
