Which parts are pin compatible replacements for the VN7140AJTR?
Brian ADS
Posted on October 16, 2017 at 21:17
I need to find suitable alternatives to the VN7140AJTR that can swapped in with zero board changes.
Is there a complete list of replacement parts available?
It looks like the VN7040AJTR is a pin compatible replacement. Can I use the VN7140AJTR and VN7040AJTR interchangeably?
Thanks,
Brian
#vn7140ajtr #vn7040ajtr
Nickname15513_O
Posted on October 19, 2017 at 15:08
Hello Brian,
you can replace the
VN7140AJTR with
 VN7040AJTR, VN7050AJTR, VN7020AJTR.
They are fully pin to pin compatible, please have a look to the following page:
http://www.st.com/en/automotive-analog-and-power/high-side-switches.html?querycriteria=productId=SC1037
Best regards
Nickname15513_O
Hello Brian,
you can replace the
VN7140AJTR with
Best regards
Posted on October 19, 2017 at 18:15
Thank you for your response!
I appreciate the help.
