2024-12-09 3:11 AM
Is it possible to start either of these Vipers up earlier than their stated HV startup voltage by sourcing VCC manually (external supply) from the Vin voltage?
2024-12-10 9:23 AM
Yes, you can do that.
/Peter
2024-12-11 2:16 AM
Thanks for confirming that. This means I can also use the Viper0P which will greatly improve my standby/"off" current consumption.
I just need to know the behavior when Vin is first supplied. Will it start in ON or OFF (ZPM) mode ?
How does the Viper behave in a no-load situation?
