2026-05-11 10:14 PM - last edited on 2026-05-11 11:12 PM by Peter BENSCH
Hello Team,
Hope you are well!
Could you confirm if the following top marking on ST4SI1M0008SCIFW is correct?
8942310525
000000923
FN527
Many thanks!
Robert
2026-05-11 11:18 PM
For a question about this device, nobody in the public community will be able to help you, so you should contact the personal Online Support OLS.
Hope that helps?
/Peter
2026-05-11 11:18 PM
Hope that helps?
/Peter
2026-05-11 11:40 PM
Thank you for your advice!
I will submit it on the online support channel.
Robert
