Supply Voltage L6229Q
mikemike9147
Posted on February 22, 2015 at 23:56
I am using the BLDC driver -L6229Q. I can see that the recommended operating conditions for the supply voltage is between 8 to 52 V.
What are the effects of supplying a lower voltage 6V? or 7V?
After testing it I have't seen any difference in the results.
P.S - Is there a similar driver that can work with those supply voltages?
0 REPLIES 0
