stwlc38 firmware download issues
daveoh
We use wireless charger RX IC stwlc38, though we tried to write firmware which provided by the link https://github.com/STwirelesscharger/STWLC38_NUCLEO_L476RG, but we met the CUT id mismatch during firmware writing via I2C interface and then the F/W writing was failed, anyone help to solve this issue or any reference code for stwlc38 or firmware?
willzhou
Hi
i think you meet "[WLC] HW cut id mismatch with Target cut id, "NVM programming aborted"
You can just remove this part of code, or you can just set
#define NVM_TARGET_CUT_ID 3
Also you can check doc/testlog.txt to get normal case one.
