STMP3x measurement calculations
Mehul Laliwala
Posted on November 06, 2017 at 21:07
Currently, I am evaluating STPM3x, but having hard time understanding how to convert register value to floating point signed integer values.
I can calculate voltage and current rms values, but I am trying to convert apparent power  (reg. 90) , active power (reg. 84), and reactive power(reg.88).
Any examples would be helpful.  Datasheet is not clear.
Thanks in advance!
1 REPLY 1
Nicolas Cuadrado
Posted on May 06, 2018 at 22:33
Hello Mehul!
I'm facing the same issue, documentation is not that clear for me, for some values i get values near to the expected when calculating by hand, but for several others i can't.
Did you find out how to understand the values?
It would be very helpful.
Regards!
