Steval-L99615C Request Refund
KWarr.1
I have tried every possible option to get the discovery kit working. I am not satisfied with your technical support. How do I return item for a refund?
Get an RMA from your distributor? Or ST if you purchased directly, use the same points of contact.
Submit a support ticket   https://www.st.com/content/st_com/en/support/support-home.html
