Sensor N, B, D Compensation Network for "Wide range air fuel sensor control interface" L9780
Options
2022-11-29 2:52 AM
I would like to know what Sensor Type N, D and B stands for in the L9780 Data sheet. Depending on the desired oxygen sensor different resistor and capacitance values are required for the compensation Network (Pins C1, C2, C3).
My assumption is following:
- Type N: NTK Sensor
- Type D: Denso Sensor
- Type B: Bosch Sensor
Could someone please confirm if that is the case?
Best Regards,
Carles
1 REPLY 1
Options
2023-04-20 10:08 AM
I would also like clarification on this matter, and can not find such documentation anywhere.
