Proper BLDC motor starting
jermakov
Posted on April 04, 2007 at 05:32
jermakov
Posted on May 17, 2011 at 10:13
I am using AK_ST7FMC Development Kit for a electrical bike design and can not be satisfied with unreliable BLDC sensor motor starting. The motor is quite powerful and is able to drive a bike with no problem, but actually it doesn't provide a required torque to move the bike from the stop point.
I guess the starting facilities may be improved by mts.c module adjustment r modification.
Is there any recommendation to adjust mtc.c software module in order to get reliable motor start up?
Thank you,
Alexander.
