2007-04-03 8:32 PM
2011-05-17 1:13 AM
I am using AK_ST7FMC Development Kit for a electrical bike design and can not be satisfied with unreliable BLDC sensor motor starting. The motor is quite powerful and is able to drive a bike with no problem, but actually it doesn't provide a required torque to move the bike from the stop point. I guess the starting facilities may be improved by mts.c module adjustment r modification. Is there any recommendation to adjust mtc.c software module in order to get reliable motor start up? Thank you, Alexander.
