2026-02-19 1:21 PM
2026-03-05 10:01 AM
Welcome @LukeIma, to the community!
Your understanding of the T0/T1/T2 encoding with CLS1 = 36.5Ω and CLS2 = 51.1Ω resistors is correct: for a Type 2 (PoE+) PSE the PM8805 should report 'T2:T1:T0 = 1:1:0', as shown in line 2 of table 10 of the data sheet.
The fact that PGD is asserted but all T0...T2 lines stay high (LEDs off on STEVAL-POE001V1 and your own board) suggests that the PM8805 does not detect the PSE as an IEEE‑802.3af/at/… compliant source, but rather as a legacy / passive injector or in a non‑standard mode.
To investigate further, could you please share:
/Peter
2026-03-05 10:01 AM
/Peter
2026-03-26 2:52 AM
@LukeIma Is the question answered with that, or can you still provide the information?
/Peter
2026-04-09 10:30 AM
@Peter BENSCH Thank you for your reply!
After much investigation we found that both the Ubiquity and TP-Link brand injectors where in fact not always compliant.
After switching to a certified industrial injector it now works.
Thank you so much for your reply
2026-04-09 10:30 AM
Yes my question was answered
Thank you very much
