2021-12-13 9:54 AM - last edited on 2025-01-15 5:28 AM by Andrew Neil
I would like to measure motor load torque using the FOC Iq current. Am I correct that torque should equal Iq*Kt. I am using the ST Motor Control SDK 5.4. I have characterized the Kt of my motor. I calculate Iq [mA] = Iq_s16 * VDD [mV/(Rshunt*Gain*65536)
When I test with a torque meter, I'm calculating roughly 2x the torque as compared to the torque meter. Is there something I'm missing in my calculation?
2021-12-13 1:57 PM
My mistake, looks like I had a problem with my setup. The calculated Torque using the above equation matches the measure torque
2021-12-13 1:57 PM
2025-01-14 9:24 PM
Which torque meter you used?
