LDO29300P2MTR
‎2025-03-28 3:58 AM
We have implemented the following circuit. This matches the application circuit given in datasheet of LDO29300P2MTR.But it does not yield expected output. We need help!!
Power Line Communication
‎2025-03-28 9:05 PM
I have attached the images for your reference. Kindly let me know if I have made any mistakes
‎2025-03-28 4:18 AM
@saran wrote:it does not yield expected output. !!
So what output does it yield ?
@saran wrote:
What is the significance of the 5.41A there?
The LD29300 is only a 3A regulator ...
https://www.st.com/en/power-management/ld29300.html
@saran wrote:This matches the application circuit given in datasheet
Not quite:
You've left the INH pin open.
‎2025-03-28 4:50 AM
The IC takes an input voltage of 24V/5.4A , expected output is 12V BUT IT GIVES 0V . Also where should I connect the INH pin.
‎2025-03-28 4:56 AM
+1
And for an output voltage of 12V that can be set within narrower limits, I would replace VR1 with 1k and connect an 8.2k resistor in series to VR1. The output voltage should then be adjustable between approx. 11.2V-12.6V.
‎2025-03-28 4:58 AM
@saran wrote:The IC takes an input voltage of 24V/5.4A
The IC takes an input voltage; the current is determined by the load.
@saran wrote:expected output is 12V BUT IT GIVES 0V . .
The output depends on R1 - so what do you have that set to?
@saran wrote:where should I connect the INH pin.
As the datasheet shows - connect it high for 'ON', or low for 'OFF':
‎2025-03-28 5:03 AM
R1 value is 10Kohm ; R2 is 1Kohm
‎2025-03-28 5:05 AM
@saran Let me tell you what is meant by INH=H: simply connect INH (pin 1) to INPUT (pin 2) to switch the LD29300 on permanently. If you connect pin 1 to GND, you switch it off.
‎2025-03-28 5:28 AM
I have shorted pin 1 and pin 2. Still, the output is 0V. If you have any sample circuits for the LDO29300P2MTR, kindly help me solve the issues.
‎2025-03-28 6:09 AM
Then check your resistors & wiring.
Perhaps show a good, clear photograph of your setup.
‎2025-03-28 9:05 PM
