L6207 signal and control With 3V3 ucontroller
Options
‎2014-01-29 4:04 AM
Posted on January 29, 2014 at 13:04
Hy, i must use a full bridge driver L6297 for control two normal DC motor 24V.
My uP is STM32 Cortex STM32F100 with 3,3 Volt supply. Can i control direcly the L6207 with 3,3 Volt level ?? for all the signal control: In digital, enable, pwm, Vref ..... Thank you
Labels:
- Labels:
Motor Control Hardware
Options
‎2014-02-03 2:38 AM
Posted on February 03, 2014 at 11:38
Hi, all the digital inputs of the L6207 are compliant with the 3.3 V logic signals and you can ajust the VREF using a 3.3 V PWM without any limitation.
Regards EnricoOptions
‎2014-02-03 3:43 AM
Posted on February 03, 2014 at 12:43
Thank you very much
Best regards Michele
