I would like to ask about the schematic in the picture below. I am trying to do the fabrication and assembly process by using the components on the schematic. but when I tried to test it, it was found that the result was not the same as the simulation. fo
Moonji
3 REPLIES 3
sorry I'm not really understand the link that you attach
Hi @Moonji​ ,
The above link refers to a request of a Community member on the simulation of SPV1050, where we provided some related material.
Consider also the possibility to use a STEVAL-ISV019V1 board, as a reference for your design.
I hope it helps.
Marco
