2015-04-05 5:14 AM
hye,
i am using StSW-stm32100 lib and WB. i am using PMSM in train model through electric traction system. my question is that can i make changes in the main.c file of the code that is generated by W.B. actually i want to start and stop motor through external signal i.e RF module, and i want to reverse the direction of motor as well so my train direction is reversed.2015-04-07 12:03 AM
Ciao
The WB don't generate the code of main.c, you can modify it to build your application program using the MC API. Ciao Gigi
