2017-02-28 6:54 AM
i am looking at using the L6668 as a multy output flyback, i need it to have a high voltage start up (which this IC does have, that is good), but i also need it to synchronise it to about 100KHz from a micro.
my question is, can the L6668 be synchronised ?.
basically it needs to run at a fixed frequency and be synchronized by an external micro.
