2020-08-28 4:39 AM
I'm using IAR 6.21. I'm trying to build a static library but even if my sources didn't change, the binary file is different each time I build again the lib.
I tried to compare the lib.a, there is some UNIX timestamps in the file that depends on the build time.
Do you know a way to prevent that? I need to have the exact same binary for the exact same sources...
Thank you,
Charles
2020-09-18 2:24 AM
Did they tell you how you actually activate this option in IAR 8.50 ?
BR
2020-09-18 2:38 AM
Hi! I think so but I'm in vacation until Monday and I will be able to see their answer then.
I suppose it is in the Linker options.
