Error when updating project configuration from Cube to Workbench
‎2018-05-24 11:06 AM
Hi there,
I've been working with eclipse-workbench for half a year now, creating my projects from STM32Cube tab inside eclipse and exporting them to eclipse. Until now everything was working fine, I could edit the .ioc file and update the configuration to eclipse without any problem.
Don't know why, but since today, when I try to create a new project or edit the ones already were working, I have the following error:
''Please install SW4STM32 toolchain to open the project.
Or associate the file type of the project with you Toolchain in System Default Program Settings''
Any clue how to solve it?
#stm32 #workbench #error #eclipseSolved! Go to Solution.
SW4STM32
‎2018-05-27 8:40 AM
I installed latest version of CUBE with no succeed. I've installed “System Workbench for STM32� again, keeping the previous installation (now I have 2 Workbenchs) and both are working now, so I'm going to keep it.
‎2018-05-25 2:56 AM
Hi
maniljo
,Do you face the issue with the latest version of CUBEMX (4.1)?
-Nesrine-
‎2018-05-25 5:17 AM
Hi
ELMHIRI.Syrine
Thanks for you answer. Right now I'm not in front of my computer, but pretty sure is above 4.
I've been using Workbench/CUBEMX oftenly for almost a year and it worked perfectly.
Quite extrange problem since it is reproduced on the projects that previously worked fine.
‎2018-05-25 5:56 AM
Hi
maniljo
,Please try to use the latest version and tel us if the issue still again.
-Nesrine-
‎2018-05-27 8:40 AM
