Error message from debugger back end: The system tried to join a drive to a directory on a joined drive.
‎2019-07-09 11:55 PM
Hi there,
Debugging stops with this error message
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
localhost:61234: The system tried to join a drive to a directory on a joined drive.
please suggest how to remove this problem.
thanks.
DEBUG
STM32L0 Series
TrueSTUDIO
‎2019-07-12 12:39 AM
Hi @barmy​ ,
1- what are you using as hardware?
2- what are you trying to do?
3- what are you expecting as result?
4- what is going wrong here?
-Amel
‎2019-07-23 3:27 AM
1) I am using STM32L072czy and True studio IDE.
2) I am trying some basic experiments like glowing LED.
3) I expect after successful flashing ,user LED should glow and st-link indicator should turn green.
4) this flashing is random, sometimes flashing is successful and many times shows error as
target extended-remote localhost:61234
also even if flashing is successful ST-LINK LED do not turn green and keeps on blinking red and green.
where i am making mistakes.
‎2020-06-16 8:41 AM
Installing STM32CubeProg fixed this error for me. I think it was a driver issue.
‎2021-02-20 1:59 AM
Did you find any solution?
