AN3966 over DevKit407 (STM32F407G-DISC1 + STM32F4DIS-BB) with TrueSTUDIO (Atollic)
‎2018-07-02 9:17 AM
Hi All,
I have a DevKit407 (STM32F407G-DISC1 + STM32F4DIS-BB) and I'm working with AN3966.
I'm using the newest version of TrueSTUDIO
Exactly, I'm trying to run httpserver_socket (with FreeRTOS) over Board.
I know that there are a lot of threads about this topic, but I can not get to run it.
My problem is that app not compile. After import project from source code examples of AN3966 (stsw-stm32070), when I try to compile the IDE said some files are not found.. for example:
..\..\..\..\..\..\Utilities\Third_Party\lwip-1.4.1\src\core\ipv4\inet.c:41:23: fatal error: lwip/inet.h: No such file or directory
But the code is just imported from example...
I tried to modify the MCU the exact model, but I got the same error.
And, I tried to make a simply led blinking from STm32CubeMX and it works.
I think that it has to be a 'easy' step, simply run a example, so I think that maybe I'm skiping some step.
Please can you help me?
(Sorry if the solution is already posted, but I found for a lot of hours, and I didn't find the solution)
Thanks!
Jordi
#atollic-truestudio #devkit407 #lwip #an3966- Labels:
Ethernet
TrueSTUDIO
‎2018-07-02 10:27 PM
The F407 Discovery itself has no Ethernet, so ST's Firmware package has no ..\Utilities\Third_Party\lwip-xxx sources.
There is a firmware package for the STM32F4DIS-BB board, downloadable somewhere on the Element14 webpage.
Pretty sure you can find it yourself.
Last time I tried the ethernet/webserver example from that package build 'out of the box'.
‎2018-07-03 1:19 AM
Dear AvaTar,
thanks for your feedback.
But, I have full source code for lwip-xxx. I can see all files.
I downloaded the example from
https://www.st.com/en/embedded-software/stsw-stm32070.html
Furthemore, when I follow the error that shows the console I can open the file that compiler says 'not found'.
So, I think it's a problem of include path in example, but I don't understand. It's a ST official ApplicationNote, it has to be 'plug&play'.
Someone check AN3966 over F407Dis with TrueStudio (Version: 9.0.1 Build id: 20180420-1214). I'm work over Win10
Jordi
‎2018-07-03 1:43 AM
Does it come with a project/workspace for Truestudio ?
I guess you expect a bit much here ... ;)
Adding an include path is a simple exercise. I use Crossworks, wich has no 'out of the box' support from ST. For porting aproject, I always spent the first 15 minutes assembling the source files, include paths and link libraries.
‎2018-07-03 3:55 AM
Yes, the example has a
TrueSTUDIO project file.
I have reach to compile the source, the 'error' was at import project. I did Import from 'Existing Projects into Workspace' and I didn't reach to compile. Now I import the project as 'Projects from Folder or Archive', so I can import and compile the file. (And, I think TrueSTUDIO has some problems with linked files....)
Only I need to modify a timeval include struct (it is documented in the code), to use the private definition or the same of system.
Now the code compiles, but it doesn't work. I think that I understand 'the problem', the
example is not ported to DevKit407, and when I change platform in TrueSTUDIO, the example not has under ifdef the pinouts.
So I think the problem is 'solved'.
Jordi
‎2018-07-03 5:02 AM
The awkward project import is one of the weak points of Eclipse IMHO.
And many paths (sources, include, libs) are expanded using Eclipse-owned shell variables, with unclear project inheritance.
