Worry about Sdip case of ST7
Options
‎2005-06-07 11:42 PM
Options
‎2005-06-05 9:16 PM
Posted on June 06, 2005 at 06:16
We heard there's a lot off delevery problems with Sdip32 case of ST72C245 and ST72F264? [In the Netherlands]
Today there isn't a problem with ST72C334, but it can be! Anybody knows also of this problem? Means this, the Sdip case will be obsolete? That will be a big problem for us. Moppie [ This message was edited by: Moppie on 06-06-2005 09:47 ]Options
Posted on June 08, 2005 at 08:42
I Moppie,
I haven't heard about your problem in france. The best solution for you is to ask your local dealer ! In any case, if the Sdip case become obsolete you will have two choices : 1 - you redraw all your cards with an active package ! 2 - you could maybe make a little PCB to adapt a Smd case on your existing board using Dip case ? Regards Whitebull
