2007-10-03 03:02 PM
Why must ICCSEL/VPP Pin of ST7 be connected to pull down 10Kohm?
2007-10-02 11:59 PM
I am using ST7F324L MCU for my appilcation. I see that it is ICCSEL/VPP Pin be connected to pull down 10Kohm. Like to know the reason for this and the effect for leaving ICCSEL/VPP pin floating. Thanks.2007-10-03 01:07 AM
Hi kea
ICCSEL/VPP must be PULLED UP by a 10 kOhm resistor to avoid entering in circuit programmig (ICP) during a reset. This is a safety measure, because after a reset this pin, if not fixed to Vdd, may float and therefore start an unwanted ICP session. Regards, EtaPhi2007-10-03 03:02 PM
Hi EtaPhi,
I am clear now. Thanks for your reply. Thanks, kea
