2024-02-29 6:23 AM
Hello every ones; i found this component from ST: 211 ST- EZ204.
Is a four pin Integrated circuit. does anyone know what it is? I cant found it data scheet
2024-02-29 8:29 AM
You can see from this that a photo is always very important: it is an SO-8 package that has eight pins instead of four. The device in question is an LM211D.
Good luck!
/Peter
2024-02-29 7:45 AM
It is always helpful to have sufficient information for a meaningful answer. In this case, a clearly legible photo of the part in question is missing. Can you please upload it?
2024-02-29 8:22 AM
2024-02-29 8:29 AM
Good luck!
/Peter
2024-02-29 8:32 AM
tks a lot, you solved my big issue))))))))thank again
