what AN describes st7 registers
omatza
Posted on September 11, 2005 at 14:33
4 REPLIES 4
omatza
Posted on September 08, 2005 at 14:54
Hello
I am totally new to st7.
what AN describes st7 registers ?
what should I read more ?
What tool set is better: Metrowerks or Cosmic ?
Oren
alok2
Posted on September 09, 2005 at 03:12
registers are explained in datasheets. which device do you use ?
if you need info about some specific peripheral you can see some AN on peripherals but not abt registers.
both tools are good.
omatza
Posted on September 11, 2005 at 12:02
Hi
Thanks a lot.
When I meant registers, I meant actually CC register description.
I don't find PDF about the assembly.
I found in one of the on-line courses, explanation about the CC.
Oren :)
omatza
I now found
http://www.st.com/stonline/products/literature/pm/4020.htm
which is the final thing I was needed
(ST7 FAMILY PROGRAMMING MANUAL)
Thaks a lot
Oren
BTW - does anybody knows something about the overlap feature of Metrowerks ?
Is it the same in Cosmic ?
(I meanis it a ganeric feature of st7, or just feature of metrowerks ?)
Oren
