2024-05-16 8:57 AM - edited 2024-05-16 9:26 AM
Since I am using this component in several applications,
I would like to know if it is still manufactured.
Normally I would just check the ST website to have the information,
but my difficulty here is that I have seen different information at different moments.
Do you know a way to be sure about the status of the component?
Using octopart some websites affirm that it is obsolete whereas others say it's active.
I don't know if the component could have been stopped then relaunch and that could be the source of the confusion?
Thank you very much for your help,
2024-05-17 11:56 AM
And one last tip: on the eSTore website you have take a screenshot from, which you can also simply link to eSTore VBG08HTR-E, there is a Notify me button at the bottom right. Just click on it, enter your email address and you will be notified when devices are back in the eSTore.
