2009-10-08 3:39 AM
Using STR75x data memory as EEPROM
2008-02-11 9:49 PM
Hello friends. I want to use STR75x data memory (Bank1 Data Memory) as EEPROM. But I can't see any functions like ''FLASH_WordWrite'' or ''FLASH_WordRead'' in STR75x library. How can I perform this operation? Can you please give me an idea? I'm using Keil. Thanks.
2009-09-16 9:28 PM
i have a problem like you. I cant access flash bank1 to write data. If you overcome this problem, could you let me know? Thank you2009-10-08 3:39 AM
Hi. Try the following flash library from ST:
http://www.st.com/stonline/products/support/micro/files/str7xfpmsw.zip
