omury
USB port reset
Posted on August 08, 2006 at 12:39
USB port reset
omury
omuryAuthor
Posted on August 08, 2006 at 07:22
Hi.
I want to reset USB port without unplugging and re-plugging cable. I tried to setting FRES and PDWN bits in USB_CNTR register. I also tried to PowerOff() function in usb_pwr.c but they are not working. How can I make the PC re-recognize my USB STR711 device?
yusuf
anis23
Posted on August 08, 2006 at 08:03
Hi Jozef,
To generate an USB reset from device point of view you have to disconnect and re-connect the pull-up resistor (on the D+ line).
You have to provide a schematic to disconnect this resistor using a GPIO pin.
Please find attached a simple example of schematic able to connect and disconnect the pull-up resistor using one GPIO, two transistors and three resistors.
AnisAs :D
________________
Attachments :
USB_reset.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtPS&d=%2Fa%2F0X0000000aPb%2FpjMKRLzxLvsHrUpPyWagUYfxL3uRU.sMdyIYh06wT_U&asPdf=false
omury
omuryAuthor
Hi AnisAs,
Thank you for your urgent reply. It's working!!!
regards
yusuf
