2006-06-13 11:22 PM
2006-06-08 4:26 AM
hi!
i download the file you can see in attachments, and i would like to know is it works with STR7 RVDK Realview debugger 1.7? when i tried to buil the project i had errors. Can you help me?? thanks!! ________________ Attachments : 1075381110.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtIH&d=%2Fa%2F0X0000000aLA%2FLPiPaMzlluSNGmODpPKvjuF9zJXCADC8ALYlMK8I4NQ&asPdf=false2006-06-09 2:50 AM
hi!!
i had add the line: PRESERVE8. but i had the same problem, when i tried to build the project, i had an error that say: 9 files missing. can you help me?? thanks2006-06-12 3:50 AM
Hi Zouhair!!!
thanks for your the projects works!!!! i would like ton know where the programm is loaded? they seemed to be loaded in RAM but in the scatter file they seemed to be loaded in FLASH. can you say me where is loaded??? thanks,2006-06-12 11:07 PM
Hi Zouhair,
when you say me to remap RAM to adress 0x00 by hardware, does it mean with switch 15,14,13?? And can you explain me why in the scat file there is specified that the programm is loaded in flash?? you can find in attachments the scat file. Thanhs,2006-06-13 11:22 PM
Hi Zouhair,
Thanks for answer. -Can you say me if it is possible to run this programm with WinIDEA? - there is files to replaced? Thanks,
