uPSD UART Mode0 Max Baud
wek1
Posted on March 01, 2004 at 14:31
8 REPLIES 8
wek1
Posted on May 17, 2011 at 11:58
The uPSD321x datasheet states (table 45) that the max. baud rate of UART in mode0 is 1MHz (constraining the Xtal freq. to 12MHz).
I haven't seen this kind of constraint in other '51 clones.
Is this true?
Have a nice day!
Jan
sjo
In uart mode0 the Baud rate is defined as Osc/12 and is fixed, as far as I am aware this has always been the case on 8051.
sjo
wek1
Yes, but what about the MAXIMUM baud rate?
Jan
jinguanghua
I have tested Modeo using uart0, I got 1Mhz.
wek1
Yes, of course, this is what I expected (as other '51 clones work this way).
But why then the ''max. 1MHz'' in datasheet of uPSD321x Table 45, page62?
Jan
PS. FrankJ, what is your device? Could you try it also @ 40MHz?
wek1
I don't quite understand:
- what was the Xtal frequency? 12MHz?
- did you try higher Xtal frequency? and mode0 baud was still 1MHz?
Jan
jinguanghua
I use 24M crystal on the board and uart 0 mode 0 mode, I got 2M speed.
jinguanghua
ST3234A, I don't have 40Mhz crystal on hand.
