UART Tx interrupt
emoktad
Posted on March 09, 2007 at 10:32
UART Tx interrupt
amira1
Posted on May 17, 2011 at 09:39
Hi usbmaster,
Could you change ''UARTx->ICR &= UART_IT'' by ''UARTx->ICR = UART_IT'' in UART_ClearITPendingBit function of 91x_uart.c.
As I see, it's due to this bad configuration.
With best regards;
mirou
emoktad
I am using the UART0 in interrupt mode , the problem is that after sending the last byte and clearing the pending interrupt the Tx interrupt still occurs ( i am not using break mode ), I want to know how to stop the Tx interrupt after last byte ( not to disable interrupts). thanks
