2006-10-13 10:42 PM
2006-10-03 8:26 PM
hello,
We use atlas evaluvation board. We used tiny bios and able to boot slackware from harddisk. Does anyone know how to add boot from cd in tiny bios and also what changes for USB support in tinybios. Tried gs bios usb working but in tinybios it is not working (Probably irq table not set in tinybios) thanks in advance Balaji2006-10-09 3:17 AM
The validated Bios working on Eval board are the one published on intranet. From where did you got the tiny bios? Did you receievedd this bios with another eval board?2006-10-13 10:42 PM
I got the bios from TinyBios website. The ''readme.txt'' notes in it says CDROM boot support not available in it we should add it ourself. So if you have the source code of tiny bios which supports CDROM boot as a request from me, can you provide me so I could look into it and try to implement it in the code I have. I hope you reply me with a positive answer thanks Balaji [ This message was edited by: balsara on 14-10-2006 11:22 ]
