There is an old question regarding the use of ST90R158 (ROMless) code in an ST90T158 (OTP) processor. I need some information on a way to accomplish this, if possible.
‎2019-10-08 9:18 AM
‎2019-10-08 11:28 AM
Perhaps actually cite the question? https://community.st.com/s/question/0D50X00009Xkd3xSAB/its-possible-to-use-st90t158otp-as-rom-less-type-st90r158-help-me
The threads are from about 8 years ago, pointing to off-site documents which are no longer available. Not sure what ST9 App Notes and Design Guides exist. Some of that is probably of the dead-tree variety. Check the book cases of departed colleagues.
‎2019-10-08 11:40 AM
APPLICATION NOTE AN1076
ST9 EXTERNAL MEMORY INTERFACE CONFIGURATION
‎2019-10-08 11:46 AM
App notes can be located under resources/technical documentation
https://www.st.com/en/microcontrollers-microprocessors/st9-8-bit-mcus.html#resource
‎2019-10-23 7:13 AM
Thank you!
