2007-06-25 4:38 AM
2007-06-25 4:38 AM
I'm using a STR750 microcontroler + an optical encoder whose resolution is 1024 ppr. I'm trying to count 1024 pulses per rotation but I only get 2048 with TIM_Mode_Encoder1 or TIM_Mode_Encoder2 (ENC = 01 or 10) and 4096 pulses with TIM_Mode_Encoder3 (ENC = 11). Is it possible to have 1024 pulses per revolution with my encoder ? ****************************************************************** // TIM0 Configuration TIM_InitStructure.TIM_Mode = TIM_Mode_Encoder1;// resolution x1 //TIM_InitStructure.TIM_Mode = TIM_Mode_Encoder1; // resolution x4 TIM_InitStructure.TIM_Prescaler = 0x0; TIM_InitStructure.TIM_ClockSource = TIM_ClockSource_Internal; // TIM_ClockSource = CK_TIM TIM_InitStructure.TIM_Period = ENCODER_PPR - 1; // ENCODER_PPR = 1024 TIM_InitStructure.TIM_IC1Polarity = TIM_IC1Polarity_Rising; TIM_InitStructure.TIM_IC2Polarity = TIM_IC2Polarity_Rising; TIM_InitStructure.TIM_IC1Selection = TIM_IC1Selection_TI1; // A input TIM_InitStructure.TIM_IC2Selection = TIM_IC2Selection_TI2; // B input TIM_Init(TIM0, &TIM_InitStructure); TIM_ClearFlag(ENCODER_TIMER, TIM_FLAG_IC1 + TIM_FLAG_OC1 + TIM_FLAG_Update + TIM_FLAG_IC2 + TIM_FLAG_OC2); TIM_ITConfig(TIM0, TIM_IT_Update, ENABLE); TIM_ResetCounter(TIM0); ************************************************************* Thank you, -Xavier ________________ Attachments : mode_codeur.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtR8&d=%2Fa%2F0X0000000aPz%2FqooZyPI1KOwpDRpfmUoLRq6k_czmOd83UzOb8PkuQNI&asPdf=false
