2008-12-10 7:13 PM
2007-12-25 4:12 PM
Hi
I’m Jong Min Ko I have an question. After downloading and then operating application program by using STR750-IAP program, interrupt didn’t occur(applIcation program didn’t work). Pls kindly let me know If you have/know any related data or remapping related startup source. Thank you. P/S I’ve applied(adapted) STR730 source, but it didn’t work. I would need STR750 data. Because STR750 data on the Website didn’t work.2007-12-26 8:57 PM
Thank you.
solve a problem2008-12-10 7:13 PM
Hi Jong,
i am also facing same problem, i am using ST731 and keil developement environment. Can you let me know how you have solve this problem. Thanks, AP
