STR712 Clock
gawied
Posted on February 01, 2006 at 15:17
STR712 Clock
3 REPLIES 3
gawied
Posted on January 27, 2006 at 18:59
Hi All
I am using the IAR STR712 KS kit. I modified the rccu example that comes with the STRxLib so that MCLK and PCLK1/2 are all on 32MHz. The LED is also toggled. Code are listed below:
RCCU_Div2Config (ENABLE);
RCCU_FCLKConfig (RCCU_DEFAULT );
RCCU_PCLKConfig (RCCU_DEFAULT);
RCCU_MCLKConfig (RCCU_DEFAULT);
RCCU_PLL1Config (RCCU_PLL1_Mul_16, RCCU_Div_1) ;
while(RCCU_FlagStatus(RCCU_PLL1_LOCK)==RESET);
RCCU_RCLKSourceConfig (RCCU_PLL1_Output) ;
MCLKval=RCCU_FrequencyValue (RCCU_MCLK);
APB1CLKval=RCCU_FrequencyValue (RCCU_FCLK);
APB2CLKval=RCCU_FrequencyValue (RCCU_PCLK);
// Configure P1.8 as Output Push-Pull
GPIO_Config(GPIO1, 0x0100, GPIO_OUT_PP);
GPIO_BitWrite(GPIO1,8,1);
while(1)
delay(); // simple for loop
GPIO_BitWrite(GPIO1, 8,~GPIO_BitRead(GPIO1,8));
My problem is that the code is executing for a few minutes and then it stops. Does anybody know what can be wrong?
Cheers
Gawie
gawied
Posted on January 30, 2006 at 17:14
Hi All
I have found the problem. In the end it had nothing to do with the clock setup, but it was due to faulty HW!!
Cheers
Gawie
gawied
Hi Zouh
Yes, I can confirm that there was some hw fault (dry joint, or something) on my STR712 KS kit. I had it replaced and my code is working fine now.
Thanks,
Gawie
