2008-08-06 09:09 PM
2008-08-06 09:09 PM
I've just a little problem using step by step debug in Softec STVD7. With the previous version, I could see the text assembly line hightlighted in yellow at each step. Now, I can only see the dissasembly code in yellow and nothing happens on the text line so it's very difficult to follow! Do anybody have a solution to that? Is there a setting to get the step by step monitoring in the text file instead of the dissasembly? Thank you for your help.
