st7lite2, some question
fantapineto
Posted on July 11, 2006 at 06:46
1 REPLY 1
fantapineto
hi,
I'm working with ST7Lite2 micro, InDart STX/Lite2 design kit and Softec STVD7 3.
I'm devoloping a motor control algorithm for a brush dc motor. This algorithm runs every pwm period. I want to test the transient response of the algorithm monitoring some variables (like voltage reference for PWM modulation).
I found an App. Note AN1754 which illustrate a ''data logging program'' for testing st7 applications via ICC protocol with a PC and ST7 stick. This program uses DLLs from the STVP7 software. Questions are:
it is possible to use this procedure with my hardware? an alternative procedure? can DataBlaze software be useful?
Filippo
________________
Attachments :
10021.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I087&d=%2Fa%2F0X0000000bTy%2FMgk.ALG7ouEvdHwfQbW3zIMUQ72a.pI4gF5BkrYk6EY&asPdf=false
