2003-02-11 6:23 AM
2003-02-10 9:26 PM
hi friends,
We are doing a smart card reader based project using ST7 .we want to implement IN APPLICATION PROGRAMMING in ST72651.Please send any related source code driver or any documents/articles or websites related to the implementation of IAP. regards, vidhyas2003-02-10 11:09 PM
You can refer Application Note (AN-1576 ) i.e. In-Application Programming (IAP) drivers for ST7 HDFlash or XFlash MCUs . You will get some idea out of it. Application note u can download from this same site. Go to downloads, ST7 microcntroller,Application Note, AN 1576.2003-02-11 6:23 AM
Hello Vidhyas,
ST has already done a reference design that implements the In Application Programming thru the USB (also called Device Firmware Upgrade (DFU) ). Now regarding the availability of a firmware supporting the DFU for the ST7265 Full Speed Micro I know that ST has been working on it recently. I'll update you on that soon. By the way, did you see that ST has a USB microcontroller dedicated to Smart Card reader application (part # : ST7SCR) ? Take care, Renaud [ This message was edited by: Renaud on 11-02-2003 19:54 ][ This message was edited by: Renaud on 11-02-2003 20:24 ]
