ST7 assembler
Options
‎2003-04-01 2:18 PM
6 REPLIES 6
Options
‎2003-03-30 1:29 AM
Posted on March 30, 2003 at 11:29
Hi everybody,
I have some questions. 1. I need to declare an array of 255 bytes in the ROM of the ST7. How can I do that? And how can I use it? 2. I need to program the EEPROM of the ST7c2334 and the FLASH. I have to write all '0' and all '1' and then read it again. How can I do that? thanks ChrOptions
‎2003-03-30 2:31 PM
Posted on March 31, 2003 at 00:31
First question
#pragma INTO_ROM const char data[256] = { ... }Options
‎2003-03-30 2:52 PM
Posted on March 31, 2003 at 00:52
second question
1. set LAT bit in CSR of EEPROM, then write all ''0'' or ''1'', 2. After you finish the write operation, you set PGM bit in CSR of EEPROM until PGM become 0. 3. clear LAT bit ,you can read the EEPROMOptions
‎2003-03-30 3:05 PM
Posted on March 31, 2003 at 01:05
Sorry!, first question my reply is C code assembler is:
segment 'rom' .data DC.B $10,$AA,$00,$BB,50,%11111101,10,$FF DC.B ...Options
‎2003-04-01 5:01 AM
Posted on April 01, 2003 at 15:01
Quote:
On 2003-03-31 04:22, DiDiDuDu wrote: second question 1. set LAT bit in CSR of EEPROM, then write all ''0'' or ''1'', 2. After you finish the write operation, you set PGM bit in CSR of EEPROM until PGM become 0. 3. clear LAT bit ,you can read the EEPROM How can I set that bit ? the EECSR is on adress $002C So I should do : bset $002C,#1 ? And how do I write? The EEprom is on 0C00h => ld A,#00 ld 0C00h,A ld OCO1,A ... ? And how can I program the flash memory? thank you ChristopheOptions
‎2003-04-01 2:18 PM
Posted on April 02, 2003 at 00:18
bset $002C,#1 ;Set LAT bit to write mode
ld A,#00 ld 0C00h,A ld OCO1,A ... bset $002C,#0 ;Set PGM bit to program .WAIT BTJF $002C,#0,OVER ;Wait PGM bit be cleared by harewre JRA WAIT .OVER In your sources you can not program the flash memory.
