2003-09-30 12:32 AM
2003-09-11 08:03 PM
I'am afraid that OSC safeguard is turn on but i don't know how can i turn it off, i don't have an access to the option bytes in my programer (this programmer scheme i took from the magazine and it works with DOS software st622xpg.bat (kit622x.exe)). Do you know how can i change theoption bytes in another way (eg. add something in the *.hex file)? Thank you2003-09-14 10:01 PM
The selection of the OSC safeguard can only be done in programming mode. Read the datasheet off ST6220C on page 16.2003-09-30 12:32 AM
Using this old Dos software(st622xpg.bat (kit622x.exe)), it is not possible to program the option byte. Actually this software was used to program B version(old devices) in which there was no option byte setting.This option byte is present in C verion devices(present devices).
The only way to program option byte is to use Winee.
