2017-11-27 9:49 PM
I'm working over a project using a66 assembly programming on ST10F269-Q3.
Since I'm very new to this environment, I would like to get some tutorial support for the mentioned.
Thanks in advance,
Salah
https://community.st.com/tags♯/?tags=assembly%20language
‌https://community.st.com/tags♯/?tags=st10%20st10f276%20keil%20c166
‌ ‌#assembly-language #st10-st10f276-keil-c166 #a66 #st10f269-q3 #assembler-keil2018-03-12 4:40 PM
Hi than I can help? I long ago
.2018-03-18 11:32 PM
Hello @Michael, Thank you so much for your attention.
Can you share a small program to receive some data on P5.3 and blink an led connected at a port (P6.0)?
I just want to start learning from the basics.
You can share me references also.
2018-03-29 11:36 AM
transfer data in potr pl5 (bit 0-7) to port pl6 ( bit 0-7)
MOVB DP6, # 0FFh;
<�?¿�?¾Ñ€Ñ‚ 6 уÑ�Ñ‚�?°�?½�?¾�?²�?»�?µ�?½ �?½�?° �?²Ñ‹Ñ…�?¾�?´!
MAIN_LOOP:
MOVB RL0,P5
MOVB P6, RL0
JMPR cc_UC, MAIN_LOOP;
2018-03-29 1:24 PM
