Sequence Write Byte in flash
raffaele
Posted on May 09, 2007 at 12:06
raffaele
Posted on May 09, 2007 at 10:38
I have perform correctly the write world command. But if I whant perform another write world command CPU stall. For what?
najoua
Posted on May 09, 2007 at 11:15
Hello invisigothux,
Before the second write operation, did you perform a wait until the first write operation is accomplished?
Najoua.
raffaele
Yes, i check the finisch of operatio, but istruction is ''world'' not ''byte'' and i write 2 byte, but i need to point only the address 0,2,4,6,8.
Now run.
If i Write address 0,1,2,3,4 CPU frezee.
