Sector 0 in FLASH program memory (ST7LITE2)
hkurt
Posted on May 20, 2004 at 11:46
hkurt
Posted on May 18, 2004 at 13:22
Can anybody tell me for what this special sector is (it has to be setup in the Option Byte).
If there is somewhere a decription pls specify where I can find it.
Kurt
itsmejatinus
The Sector 0 can be used for in-application programming(IAP). The reset and interrupt vectors are located in Sector 0. Pls also refer ''flash programming manual'' . It can be downloaded from the same site.
