2022-06-20 02:32 AM
Bonjour. Pour éviter de jeter je répare une alimentation Husqvarna .Un transistor de puissance J FET est HS Je ne trouve pas les références sur le marché. Voici les inscriptions y figurant de haut en bas. .Fabricant ST boitier TO220
e3 g
2LNM60ND
G4065 V3
CHNG4 L4L
Un grand merci pour votre aide et votre réponse.
Cordialement
2022-06-21 12:23 AM
If the problem is resolved, please mark this topic as answered by selecting Select as best under your preferred answer(s). This will help other users find that answer faster.
Good luck!
/Peter
2022-06-20 03:37 AM
Welcome, @pscha.1, to the community!
I've translated your question with a web-based translation tool to increase the chances that you will get an answer from our experts and community members, as the majority communicate in English:
Hello. To avoid throwing away I am repairing a Husqvarna power supply. a power transistor J FET is out of order. Here are the inscriptions appearing there from top to bottom. .Manufacturer ST box TO220
Can you please upload a photo of the component that is as legible as possible?
/Peter
2022-06-20 04:50 AM
2022-06-20 05:06 AM
21NM60ND
https://www.mouser.com/ProductDetail/STMicroelectronics/STW21NM60ND?qs=eQsPqqG3NqZFUUsw6ELOMA%3D%3D
https://www.mouser.com/datasheet/2/389/sgsts36976_1-2282604.pdf
2022-06-20 05:10 AM
You could try to replace it e.g. by the STW26N65DM2 or the STW35N65DM2.
Good luck!
/Peter
2022-06-21 12:23 AM
Good luck!
/Peter
